Hello guys, is it possible to open a parking lot gate, with the sending of an analytical event using the mip sdk and xprotect LPR? If possible, any guide that you can suggest?
Thank you
Thank you
Simplest solution is to use an output on a camera to control the gate.
Hi Rie Kito, thanks for the answer, if I had already considered that option, I just can’t find how to link the output of the device with an analytical event, there is some guide on which I can base myself
Thank you
Thank you very much for all your support Rie Kito
