thanks to this guide and some test we made, we are able to recover an orphan database, just copying - as the guide says - empty archive_cache.xml and config.xml file. Importing this DB using a 2020 R3 player is impossibile, because this version generate this error: “At least one database file is using an unsupported encryption algorithm”. Or asks for a DB password.
We solved the problem using 2020 R1, but there’s any way to do the same thing using 2020 R3? Or maybe to know our DB password in clear?
Thanks a lot!
