I am doing a custom .NET Application to access live view and playback.
I would like to reproduce similar UX that you have in Smart Client but for now, the controls I found out doesn’t look like that.
I have checked the following example. Within the example there is a picture of SMART Client where the independant playback is being showed. When I saw it first time, I thought the code will provide the same control design as it was stated in the image, but after integrate the control in my App, the design was quite awful (see the attached picture).
https://doc.developer.milestonesys.com/html/samples/SCIndependentPlayback.html
Having said that, is there any example that provides similar playback control design than you have in SMART Client? Before going forward to design it myself (because it’s time consuming) I would like to confirm if there is something you can share that I have missed from your documentation.
Thanks in advance.
Regards.
