I’m using the mobile web SDK to playback on my website. I have an issue where, when reaching a time segment without a recording, I need to jump to the segment with a recording. Can you help me find a way to automatically jump to the segment with recorded data when the playback reaches a segment without it?
Thank you very much!"
The default behavior in playback is that gaps are skipped. So , it should play smoothly by default. The only exception of that is if the gaps are too small.
So, what is the size of the gaps you have?
Can you please provide info about your system - Mos version
Can you provide more details how playback is initiated - commands, parameters, is i ta single camera or multiple
KR,
Svetlana
