Playback streaming always shows message "No recordings available"
We have a 32bit WPF application. We want to make a “MileStone Component Integration” using MIP SDK. Our goal is to communicate with MileStone VMS and determine the PTZ Type(Absolute or Continuous or Relative) of a particular camera.
To implement playback streaming we are referring the MileStone’s sample application “PlaybackWpfUser
In our application, within the same Window we are using two VideoOS.Platform.Client.ImageViewerControl: one for live and other for playback streaming. For playback, along with the ImageViewerControl, we are also using the PlaybackWpfUserControl.
Live camera streaming is working fine. But we are always getting the message “No recordings available” for playback streaming.
My code for Playback streaming is as follows:
XAML
xmlns:platformclient=“clr-namespace:VideoOS.Platform.Client;assembly=VideoOS.Platform”
<platformclient:ImageViewerWpfControl x:Name=“_playbackImageViewerControl” />
<platformclient:PlaybackWpfUserControl x:Name=“_playbackUserControl” Visibility=“Visible” Grid.Row=“1”/>
.CS
FQID _playbackFQID;
_imageViewerControl.Disconnect();
_playbackImageViewerControl.Disconnect();
_playbackImageViewerControl.EnableDigitalZoom = false;
_playbackImageViewerControl.MaintainImageAspectRatio = true;
_playbackImageViewerControl.EnableVisibleHeader = true;
_playbackImageViewerControl.EnableVisibleCameraName = true;
_playbackImageViewerControl.EnableVisibleLiveIndicator = true;
_playbackImageViewerControl.EnableVisibleTimestamp = true;
if (_playbackFQID == null)
_playbackFQID = ClientControl.Instance.GeneratePlaybackController();
_playbackUserControl.Init(_playbackFQID);
EnvironmentManager.Instance.Mode = Mode.ClientPlayback;
_playbackUserControl.SetCameras(new List() { SelectedCamera.FqId });
_playbackImageViewerControl.PlaybackControllerFQID = _playbackFQID;
_playbackImageViewerControl.CameraFQID = SelectedCamera.FqId;
_playbackImageViewerControl.Initialize();
_playbackImageViewerControl.Connect();
_playbackImageViewerControl.Selected = true;
if(alreadyVisited == 1)
EnvironmentManager.Instance.SendMessage(new VideoOS.Platform.Messaging.Message(
MessageId.SmartClient.PlaybackCommand,
new PlaybackCommandData() { Command = PlaybackData.PlayStop }), _playbackFQID);
                        new PlaybackCommandData() { Command = PlaybackData.Goto, DateTime = startTime.ToUniversalTime() }), \_playbackFQID);
new PlaybackCommandData() { Command = PlaybackData.PlayForward, Speed = playBackSpeed }), _playbackFQID);
Can you see playback video in the 32 bit Smart Client?
When you run this sample, does it fail in the same way?
https://doc.developer.milestonesys.com/html/index.html?base=samples/videoviewer2playback_sample.html&tree=tree_2.html
Thanks for the reply Rie. But my playback streaming is working now. It seems there was some setting related issue and after fixing the issue, streaming is working. But I have a query. Let us consider that I have 64 bit VMS and I am doing a component integration on 32 bit WPF application and access the VMS from the 32 bit application. Will the bit mismatch create problems in getting camera streaming?
This is no concern, the protocol communication between VMS(64bit) and 32bit application should work.
