Plugin-defined Items as Alarm Source
Hello. I’m developing an Event Server plugin that handles alarms from another system and sends it to the Event Server. I’m using the code from LibraryEventGenerator sample to create my alarms. I wanted to know if it’s possible to specify a plugin-defined item as the EventSource of the alarm?
Yes. You can use our old Access Control sample in order to:
1. Create the items
2. Then use the item when the event generates
