Hi Guys, I did a penetration testing and during the capture I came across Port 8443 with some form of authentication I reckon. I couldnt find anything abt 8443 in the system architecture doco. I did find some links on web auth for few integrations using port 8443. Can someone throw some light on the same ?
Please note that I would be very surprised if you find this port in use unless you use the integration mentioned above or specifically changed default ports.
Please also note that this is not related to software development with the MIP SDK, which is the focus of this forum, please ask again in the support community, you should get better help from the partners using the support community.
Thanks for that. actually the packet capture was done on the mobile phone running the milestone mobile app. I will check with the support group anyawys.
