This question doesn’t quite seem to fit in the MIP forum as I am not attempting to use the SDK itself to affect a change.
My client has a few Milestone systems and each one manages anywhere from 350 - 650 cameras each. Because of this, I cannot use the Milestone built-in motion detection as it will overwhelm the server resources, so I am using the built-in Axis Object Analytics instead. The Axis Object Analytics also allows me to specify what in the scene I am focusing on to detect motion (people, cars, bicycles, etc.).
So, here is the issue… I defined in each camera an Analytics event (Profile 1) for the AXIS Optimizer plug-in to monitor as a triggering event (Rising/Falling). I have also declared the two related events in the Events tab of each camera:(CameraApplicationPlatform/ObjectAnalytics/Device 1Scenario 1(Object Analytics 1) Rising (CameraApplicationPlatform/ObjectAnalytics/Device 1Scenario 1(Object Analytics 1) Falling
I also created a custom Rule:
“Perform an action on CameraApplicationPlatform/ObjectAnalytics/Device1Scenario1 (Object Analytics: Scenario 1) Rising
from All Cameras - Record Motion
start recording immediately on the device on which event occurred
Perform stop action on CameraApplicationPlatform/ObjectAnalytics/Device1Scenario1 (Object Analytics: Scenario 1) Falling
stop recording 15 seconds after”
The rule works in that it triggers and records the action, but I need it to record both 15 seconds before and 15 after the action. I am getting the 15 seconds after, but the rule will not allow me to change the “start recording immediately” to 15 seconds so that I get the pre-event recording. I do have the Record tab settings enabled, complete with the 15 seconds pre-buffer setting specified. My client is a city and their policy states that their CCTC system must record starting 15 seconds before the triggering event.
Am I doing something wrong? Is there another way I need to do this?
