I was using sample application from this link:
https://doc.developer.milestonesys.com/html/samples/StatusViewer_sample.html
but the application is unable to receive statuses from event server. I tried to open URLs to the service from the dev machine:
http://[server_address]:22331/central/mapservice
http://[server_address]:22331/central/statusservice
the service can be opened. The application cannot use VideoOS.Platform.Messaging.Message to retrieve statuses. Also MilestonePSTool cmdlet Get-ItemState returns “Unable to Transmit”.
Did you have the similar problem?
Details:
Milestone XProtect Corporate 2017 R2
