Problem using Hardware accelerator.
Hello!​
We are developing using MIPSDK, and we are implementing the function of receiving Frame using ‘JPEGLiveSource’ from Milestone server and delivering it to other analysis software. When setting the H / W Accelerator function to ‘AUTO’ and importing 48Chennel images, it was confirmed that the CPU uses 39% but the GPU uses only 6%.
We are Windows Server2016. Windows Server2019 server os confirmed this same problem. The graphics card is an NVIDIA Quadro P4000 model.
Checking your company’s H / W Accelerator Graphics card Support List (https://dqhg7aoeit2za.cloudfront.net/m/533db69e1bdbdecd/original/NVIDIA-Graphics-Card-Support-List.pdf) NVIDIA Quadro P4000 model is a Desktop Product It is confirmed. If the graphics card is used in the server os, may the H / W Accelerator function be unavailable?
Or is there another problem?
Please respond to the problem.
Can you please check if the same symptom happens when you use Smart Client, not your integration?
https://developer.milestonesys.com/s/article/hardware-acceleration-in-Smart-Client-2018-R1-and-newer
Can you please ensure the graphics driver is up to date?
