Problem with Plugin event integration
We are running some tests to develop event integration through the MIP Plugin SDK (2019R2).
We run a test with a simple plugin template:
1 - Disconnect the VMS event server; - OK
2 - Move the generated “itmi.dll” and “plugin.def” files to the “/milestone/MIPPlugins/test/” folder; - OK
3 - Start the VMS event server; - OK
4 - Execute Management VMS(Corporate 2017R2); - NOK
When performing step 4 listed above, the system parses the following error:
(We are using the 2017R2 version of XProtect Corporate because that is what our client uses.)
TITLE: MIPPluginLoad (itmi.dll)
Could not load VideoOS.Platform.Client.PropertiesWpfUserControl type from assembly VideoOS.Platform, Version = 1.0.0.0, Culture = neutral, PublicKeyToken = bc60fba4a7969f89.
ADDITIONAL INFORMATION:
BUTTONS:
OK
https://developer.milestonesys.com/s/article/XProtect-Management-Client-cannot-load-MIP-plugin
Thank you very much, it worked!
