Problems Reloading Config
Hello Im using the Event Server for getting the change indication in RegisterCommunicationFilter (SystemConfigurationChangedIndication) but is not working anymore. I also test this example https://github.com/milestonesys/mipsdk-samples-component/tree/main/ConfigUpdated with the MIP SDK version 2023 and Milestone Server with version 2020. At the biginning the configuration reloads properly when I made changes throw the management Client. After reinstaling Milestone ann EventServer in the server this functionality stop working. Theres aditional config that I must consider?
Looking after the MIP Log it seems the message is delivered but we the handler doesn’t trigger
imageThis is de MIP Log
The 2020 version is so old that it is not supported any longer. Milestone Support will not go into a deeper investigation. https://www.milestonesys.com/support/software/product-lifecycle/
