I’m looking for a way to re-use existing Milestone panes or controls in my own plug-in.
For example, when you click on one hardware device, on the right side, a pane is drawn with info, settings, etc. Same goes for a camera for example.
I want to re-use that pane in a custom plug-in. I suppose the only input for such a pane should be the hardware item or camera item.
I know in fact this should be possible using reflection.
Is someone able to give me an example of how this can be achieved in Milestone?
Kind regards,
Kenny
