I am attempting to use the Open Network Bridge to pull VOD via RTSP. I have set it up and can use the url via VLC for playback fine. However, I’m attempting to integrate this into a Gstreamer application, but am receiving a 455 error. I haven’t seen this documented anywhere so hoping one of you can shed some light.
I’m using a URL like:
rtsp://onvif:pw!@192.168.7.235:554/vod/DF7BF311-8637-4914-9A72-5F5D75412EEA
with a gstreamer command like:
GST_DEBUG=rtspsrc:6 gst-launch-1.0 rtspsrc location="rtsp://onvif:pw!@192.168.7.235:554/vod/DF7BF311-8637-4914-9A72-5F5D75412EEA" onvif-mode=true is-live=false tcp-timeout=0 onvif-rate-control=false ! queue ! rtponvifparse ! rtph264depay ! avdec_h264 ! videoconvert ! timeoverlay show-times-as-dates=true datetime-format="%a %d, %b %Y - %T" ! tee ! queue ! glimagesink
Note that this Gstreamer pipeline has been pulled from the Official Gstreamer Onvif Client code here: https://github.com/GStreamer/gst-rtsp-server/blob/master/examples/test-onvif-client.c
I’m receiving the following logs: https://gist.github.com/mattfeury/49220710a75fd95a0658acf804a006a8
