I have read through https://developer.milestonesys.com/s/question/0D50O000049rc7RSAQ/c-media-toolkit-raw-image which seems to be running into the same issue but I don’t see what I’m doing differently from the proposed solution.
Here’s the configuration XML used to create an ImToolKit instance.
"<toolkit type='source'>"
" <provider>mmp</provider>"
" <config>"
" <image_color_format_convert format='BGR24'>"
" <video_decoder number_of_threads='4'>"
" <toolkit type='source'>"
" <provider>is</provider>"
" <config>"
" <server_uri>" + vmsRecorderUri + "</server_uri>"
" <device_id>" + cameraId_ + "</device_id>"
" <compressionrate>100</compressionrate>"
" <alwaysstdjpeg>no</alwaysstdjpeg>"
" <media_type>VIDEO</media_type>" + authorizationToken_ +
" <maximum_queue_size>5</maximum_queue_size>"
" </config>"
" </toolkit>"
" </video_decoder>"
" </image_color_format_convert>"
" </config>"
"</toolkit>";
I used the ComponentSample config, removed the JPEG transcoding and added image_color_format_convert, compressionrate, and alwaysstdjpeg elements (but even if I omit the last two the issue persists).
Then, my code to retrieve images - with downcasting to ImImage - looks like this:
// NmToolkit::ImData * imData_
if (liveSourceToolkit_->GetLiveData(imData_, 3000) == NmToolkit::ImLiveSourceToolkit::LIVE_DATA_RETRIEVED)
// Downcast to bitmap image
NmToolkit::ImImage * imPtr = dynamic_cast<NmToolkit::ImImage *>(imData_);
if (imPtr != nullptr)
switch (imPtr->GetImageFormat())
case NmToolkit::ImImage::BGR24:
// Query data size/pointer/perform conversion
case NmToolkit::ImImage::RGB24:
I am able to get the SDK to send me either BGR24 or RGB24 formats but I can’t get through to the actual data - GetDataPointer() and GetMediaBodyPointer() both return nullptr. However, something seems to be in there because ImImage reports the correct image size (though I’m confused why it’s reporting that there’s only one plane/channel, I expect 3)
// Output of imPtr->GetImageWidth(), imPtr->GetImageHeight()
Image dims are w=1280, h=720
// Output of imPtr->GetPlaneHeight(0), imPtr->GetPlaneHeight(1), imPtr->GetPlaneHeight(2), imPtr->GetPlaneWidth(0), imPtr->GetPlaneWidth(1), imPtr->GetPlaneWidth(2)
Plane data size, h0=720, h1=0, h2=0, w0=1280, w1=0, w2=0
