Recording Server Stopped continuous
Milestone XProject Recording Server stops again shortly after restart.
Can you help with the topic?
If I understand the situation correctly you are experiencing errors and you have not developed an integration using the MIP SDK that cause this error.
Please ask again in the support community, you should get better help from the partners using the support community.
