Reference Cameras to Description Field Instead Of Name Field
We are currently looking after a site that uses a 3rd part PSIM to over lay the steams taken from milestone mobile servers. The cameras are currently referenced into the 3rd part system using the Name field, My question is, would it be possible to reference the cameras in the 3rd party system using the Description field instead of the name field?
If any one could advise I would be very grateful, Thank you.
Chris
Hi Chris,
Can you be more specific. What Milestone API you are using right now? Where do you get ‘Name field’ from and where the desired ‘Description filed’ is?
