Regarding Live audio transmission between Cameras
Dear all,
Is there a way where we can use audio in jack of one CCTV camera and connect a mic to it and then use audio out of another camera within the same network for a Live audio transmission ?
I have different brand of cameras on network like Axis, Bosch and Matrix.
Out of the box it doesn’t work that way. I think you can develop an integration that can work that way and relay a microphone from one camera to the speaker of another camera.
I recommend that you explore the Video Viewer 2-way Audio sample.
https://doc.developer.milestonesys.com/html/index.html?base=samples/componentsamples/videoviewer2wayaudio/readme.html&tree=tree_2.html
One of the beauties of working with Milestone XProtect is that it should not matter which brand the camera is as long as video and two-way audio is supported.
