RequestChallenges - NotAllowedInThisState 23
I have a system with 2 mobile servers and a load balancer that is configured to switch between them. Encryption is enabled and the server certificate is added on each mobile server for mobile streaming. However, I did observe the following error in the browser’s console. How can I fix it? and what is the reason behind it?
is it you developing a client and getting this request. if this is the case , can you please explain what sequence of commands you send to Mobile server.
KR,
Svetlana
@Svetlana Ulyanova​ I’m helping a customer configuring the mobile servers to work with a load balancer. They can login to the web client using the load balancer and stream the videos, but they get this error and we are not sure why.
