SaveItemConfiguration/GetItemConfiguration fails with specific string patterns in Management Client 2025 R3
I’m running into an issue when using SaveItemConfiguration and GetItemConfiguration, and I’m hoping someone can help me understand what’s going wrong.
This happens in Management Client 2025 R3.
Steps to reproduce
  • Save
FQID fqid = new FQID(EnvironmentManager.Instance.MasterSite.ServerId)
    ObjectId = Guid.NewGuid(),
    Kind = TestConfigPluginDefinition.TestConfigPluginKind
item = new Item(fqid, "TestConfigItem");
item.Properties["TestConfigProperty"] = content;
Configuration.Instance.SaveItemConfiguration(TestConfigPluginDefinition.TestConfigPluginId, item);
  • Get
List<Item> items = new List<Item>();
items = Configuration.Instance.GetItemConfigurations(
    null,
    TestConfigPluginDefinition.TestConfigPluginKind);
Observed behavior
The issue only occurs for certain values of content.
Causes an error
{“Cameras”:[{“Name”:“ABCDEFG 111111-1111-11[1-22]”}]}
{“C”:[{“Name”:“ABCDEFG 111111-1111-11[1-22]”}]}
{[{“ABCD”:“ABCDEFG 111111-1111-11[1-22]”}]}
Works normally (no error)
{“Cameras”:[{“Name”:“ABCDEFG 11111-1111-11[1-22]”}]}
{“C”:[{“Name”:“ABCDEF 111111-1111-11[1-22]”}]}
{“C”:[{“ABCDE”:“ABCDEFG 111111-1111[1-22]”}]}
Question
Does anyone know what could be triggering this?
Specifically:
Is there a known validation/parsing rule that rejects strings containing patterns like 111111-1111-11[1-22]?
Is this expected behavior, or does it look like a bug in 2025 R3?
Any insights (or suggested workarounds) would be greatly appreciated. Thanks!
I reproduced your observations. I have reported this to Milestone Development and we will have to await their feedback.
A patch for the Management Client is now in testing. I will update you when it is available.
This is a patch for XProtect Management Client 2025R3
https://milestonedownload.blob.core.windows.net/files/Hotfixes/25.3/ManagementServer/Milestone.Hotfix.202601230804.MS.25.3.17737.2364.exe
https://milestonedownload.blob.core.windows.net/files/Hotfixes/25.3/ManagementServer/Milestone.Hotfix.202601230804.MS.25.3.17737.2364.exe.integrity.xml
https://milestonedownload.blob.core.windows.net/files/Hotfixes/25.3/ManagementServer/Milestone.Hotfix.202601230804.MS.25.3.17737.2364.ReleaseNotes.txt
Now the patch is also included in the general patch for the XProtect Management Server 2025R3 found here.
