Hi we have no of questions below which need to be answered please
- Is there any performance requirement or limits with the performance of the Milestone MIP SDK interface?
- We need the detailed description of the data being presented to SCADA e.g. what format, text strings numerical etc. An example would be helpful?
-Could you please confirm that these characters for the input / output identifiers, e.g. “_”, “A” to “Z”, “0” to “9”. An identifier is characterized by: _<SDK_server>__ will be used in the integration?
- Could you please send us sample of source code for the MIP SDK platform?
There is no SCADA support in the MIP SDK. There is some thing else, a free software (no support) OPC server DA 2.0, it might fit what you are seeking. See here (https://force.milestonesys.com/support/MccRedir?art=000001748&lang=en_US)
Dear Team, I think there is misunderstanding. SCADA team will create their own application. SCADA will integrate to Milestone & it’s not that Milestone needs to manage SCADA points. In other words we need to ask how they can use MIP SDK to create their own application/Plug-in which will work with Milestone. Could you please give us answer for the below questions? - Is there any performance requirement or limits with the performance of the Milestone MIP SDK interface? - We need the detailed description of the data being presented to SCADA e.g. what format, text strings numerical etc. An example would be helpful? -Could you please confirm that these characters for the input / output identifiers, e.g. “_”, “A” to “Z”, “0” to “9”. An identifier is characterized by: ___ will be used in the integration? - Could you please send us sample of source code for the MIP SDK platform? Best Regards, Elshazly Mohamed SIEMENS Ltd. SA RC-SA BT SSP EXE Siemens Limited Saudi Arabia Business Gate, Building C-1, Airport Road, Qurtubah District P.O.Box 9510 Riyadh 11423, Saudi Arabia Mob : +966 - 558456086 Email : Elshazly.Mohamed.ext@siemens.com Web : www.siemens.com.sa
There is a lot of samples in the MIP SDK, Please download it install it in a strong developer PC with Visual Studio 2016.
There is no specification how the developer machine or your XProtect test setup should look like.
Please use the MIP SDK documentation and the samples.
I am afraid I do not understand this question. Using the MIP SDK you have access to camera information like camera names etc.
I suggest you install the MIP SDK, as first samples to explore I recommend the VideoViewer sample and the ConfigAccessViaSDK.
Dear Support, · For Question no 1 – Is this mean that the samples inside the SW package MIP SDK 2016 itself · For Question no 2 – Is this mean the limitation will be depending on how they develop the program? · For Question no 3 Could you please share with us the documentation of the MIP SDK? · For Question no 4 -Could you please confirm that these characters for the input / output identifiers, e.g. “_”, “A” to “Z”, “0” to “9”. An identifier is characterized by: ___ will be used in the integration? I am afraid I do not understand this question. Using the MIP SDK you have access to camera information like camera names etc. Is this mean that they will not be able to control the camera (start feeding / recording … etc)??? Best Regards, Elshazly Mohamed SIEMENS Ltd. SA RC-SA BT SSP EXE Siemens Limited Saudi Arabia Business Gate, Building C-1, Airport Road, Qurtubah District P.O.Box 9510 Riyadh 11423, Saudi Arabia Mob : +966 - 558456086 Email : Elshazly.Mohamed.ext@siemens.com Web : www.siemens.com.sa
Yes.
Yes.
Please download the MIP SDK as described here (https://force.milestonesys.com/support/MccRedir?art=000001257&lang=en_US)
No. You can interact with the system.
The answers might be cut a little short. Please take the time to download and do a little first hand exploring. The MIP SDK does require some developer experience, best and most easy is working with the .NET library. Likewise it is a good idea to have experience using the Milestone XProtect VMS.
Once you have the MIP SDK you might have new questions. Do not hesitate to ask (perhaps start a new thread)..
