When I repeatedly applied filters, a previous filtered result seems to remain after the filter value changed. To demonstrate it, I modified the method SearchInteral in the SCSearchAgent in the mipsdk-samples-plugin as follows:
private void SearchInternal(Guid sessionId, DateTime from, DateTime to, IEnumerable<Item> items,
bool ascendingSortOrder, CancellationToken cancellationToken)
// This implementation is for demo purposes only: creates dummy search result per camera.
// Respecting the provided sort order(i.e.delivering results in that order) can help reduce "flickering results" in the results
// list in Smart Client. Since this sample is based on random trigger times, respecting the sort order does not make much sense.
// If however you retrieve results from a database or similar, it is very much encouraged to respect the provided sort order.
var totalSpan = (to - from).TotalMilliseconds;
var ordinal = 0;
var speciesValue = (StringFilterValue)SearchCriteria.GetFilterValues(SpeciesFilter).FirstOrDefault();
var activityValue = (BoolFilterValue)SearchCriteria.GetFilterValues(ActivityFilter).FirstOrDefault();
var rnd = new Random(37);
if (activityValue != null && activityValue.Value)
return;
foreach (Item camera in items)
if (cancellationToken.IsCancellationRequested)
break;
var triggerTime = totalSpan * rnd.NextDouble();
const string title = "Animal found!";
var endTime = from.AddMilliseconds(triggerTime + totalSpan / 5);
foreach (var ss in
Enumerable.Range(0, 5000)
.Select(x =>
return Guid.Empty;
var id = GuidUtil.Create(SCAnimalsSearchAgentPlugin.PluginId,
title,
camera.FQID.ObjectId.ToString(),
from.AddMilliseconds(triggerTime).Ticks.ToString(CultureInfo.InvariantCulture),
endTime.Ticks.ToString(CultureInfo.InvariantCulture), ordinal.ToString());
var result = new AnimalsSearchResultData(id)
Title = title,
Item = camera,
RelatedItems = null,
BeginTime = from.AddMilliseconds(triggerTime - totalSpan / 10),
TriggerTime = from.AddMilliseconds(triggerTime),
EndTime = endTime,
WarningText = activityValue != null && activityValue.Value && ordinal == 1 ? $"Animal is eating" : "",
Species = speciesValue != null ? speciesValue.Text : PickRandomSpecies(rnd),
Ordinal = ordinal++,
FireSearchResultsReadyEvent(sessionId, new[] { result });
return id;
In the above code, when ‘Animals eating’ is filtered, returning no result is intended. However, in runtime, a result remains.
I am attaching a video that shows this behavior.
