SDK 2017- Missing Library VideoOS.Platform.SDK.UI.dll, while loading ImageViewerController
Windows application throwing error VideoOS.Platform.SDK.UI.dll while loading ImageViewer Control.
I did follow all the instructions such as post build event to copy all necessary dlls (except J2kCorex.dll is missing in the SDK bin folder).
Register the VIewerImageControl through regserv32 command.
List of dlls included in the project post build(verified with copyViewImage batch file)
xqilla23.dll,
xerces-c_3_1.dll,
VideoOS.UI.Common.WPF.VideoPlayer.dll,
VideoOS.Toolkit.dll,
VideoOS.Platform.SDK.dll,
VideoOS.Platform.Primitives.dll,
VideoOS.Platform.dll,
VideoOS.DirectXMW.DirectSound.dll,
VideoOS.DatabaseUtility.MediaStorage.dll,
VideoOS.DatabaseUtility.Common.dll,
AudioPlayerDotNet.dll,
AudioPlayerDotNet_axinterop.dll,
AudioPlayerDotNet_interop.dll,
boost_*.dll (5 dlls),
CoreToolkits.dll,
ic*.dll (2),
ImageViewerDotnet.dll,
ImageViewerDotNet_axinterop.dll,
ImageViewerDotNet_interop.dll,
IMV1.dll,
ms*.dll (4),
mf*.dll (2),
and Phyton27.dll.
Our application was running successfully with older version of Milestone 2014.
What am I missing here? I even copy and pasted missing J2KCorex.dll but not use.
Any help much appreciated.
Thanks,
After 2014 version the MIP SDK was switched to being 64-bit primarily. I suspect that is causing the issue. See - https://force.milestonesys.com/support/articles/en_US/How_To/Processor-architecture-compatibility-for-the-Milestone-Integration-Platform-MIP-SDK
Thanks, It is because I referenced 64 bit version. My application is loading ImageViewerControl now.
