Hi, goodmorning,
Hi have one integration using the SDK and I support the Milestone Corporate and Professional. I have one doubt the SDK of Milestone Husky is different of Milestone Corporate/Professional?
Thanks for your attention.
Best Regards Luis Oliveira.
Luis,
to answer your question properly, you have to state which Husky you are using:
- Husky M50 uses eithe XProtect Enterprise or Corporate
- Husky M30 uses XProtect Professional
- Husky M10 uses a completely different software
In case of the former two, you can indeed use the SDK. In case of the latter, you can not. /Torsten
Husky M50 uses XProtect Professional
Husky M50 Advanced uses XProtect Corporate
Husky M10 uses “Arcus”
You can use the MIP SDK for all of them!
See also - https://force.milestonesys.com/support/articles/en_US/FAQ/About-MIP-SDK-compatibility-with-XProtect-product-versions
In the “Arcus” product the support is with the words the MIP Documentation:
Arcus Support: A set of classes will now also support the Arcus products, this is mainly getting the configuration and retrieve video in live and playback with the JPEGVideoSource, JPEGLiveSource, BitmapVideoSource and BitmapLiveSource classes.
