We have an application which exports recorded video from Milestone using the DBExporter class. However, when we try to export footage that was retrieved from Edge Storage the resulting export completes without any errors but does not contain any video.
We are using the basic code from the ExportSample SDK example (just an example below:)
var cam = GetCamera(id);
var exporter = new DBExporter(true)
Encryption = false,
SignExport = false,
PreventReExport = false,
IncludeBookmarks = false,
exporter.Init();
exporter.CameraList.Add(cam);
exporter.Path = outputPath;
exporter.StartExport(dtStart, dtEnd);
This is a key feature for our product to export footage whether it was recorded by Milestone or retrieved from Edge Storage.
Is this a known issue and is there a work-around / solution that we can use?
