SDK to Enable PTZ
Can someone direct me what function to use on how to enable camera PTZ using SDK?
If you use the Config API Client you find it under the camera settings.
If you use the strongly typed classes it is still often a valuable hint to find it in the Config API Client, it gives a hint on the structure and how to find your way..
