I was using the SOAP method RecorderCommandService.BookmarkSearchTimeAsync, but this SOAP Api is now flagged as legacy.
The new bookmarks API has an endpoint (“bookmarks?task=searchTime”) which seems to behave similarly.
However, the request body documentation only has the field “searchHeader” (boolean) but no way to actually pass the value to search for.
Moreover, I cannot search for camera ids which was also possible with the SOAP endpoint.
What is the correct way to search for bookmarks related to a camera and with a specific header?
I appreciate any help regarding this!
For searchTime, add a “searchText” : “what-to-find” field. Also be sure to include the type like “resourceTypes” : [ “cameras” ], or the “devicePaths” : [ { “type” : “cameras”, “id” : “some_id”} ]
More info here:
https://doc.developer.milestonesys.com/mipvmsapi/api/bookmarks-rest/v1/#tag/Bookmarks/operation/bookmarks_Post
To get a specific bookmark you do a GET /bookmarks/{id-of-bookmark}
I did a quick test:
POST /api/rest/v1/bookmarks?task=searchTime
“time”: “2025-10-09T10:30:22Z”,
“searchText”: “Quick bookmark”,
“devicePaths” : [ { “type” : “cameras”, “id” : “db7b91a8-572d-4334-8314-832d6d9dbc82”} ],
“timeLimit”: “20:00:00”,
“countLimit”: 3,
“searchHeader”: true
