Security Policy violation when connect to VMS server
How can I fix this problem using the SDK Mobile?
I get an error when I try a connection request .
The error is "Refused to connect to ‘http://serveraddress/xprotectmobile/communication’ because it violate the following Content Security Policy directive: “connect-src ‘self’ ws://*:* wss://*:* https://www.google-analytics.com/ https://firebaseinstallations.googleapis.com/”.
Ajax.js 64
PS: if the web application is in the same VMS server everything works fine.
How I fix it?
It looks like your web application defines a CSP header, which is good, but you need to add an entry so that your browser is allowed to make JS requests out to your Mobile Server.
https://developer.mozilla.org/en-US/docs/Web/HTTP/CSP
