Sensor Monitor - GetItem(FQID fqid) method Event Server calls
Hello, I was looking at the Sensor Monitor plugin and modified the GetItem(FQID fqid) method to add a log, because I was interested in when this was called, since I figured this method was important to have items on the maps.
The modified GetItem is as follows:
public override Item GetItem(FQID fqid)
	EnvironmentManager.Instance.Log(false, "Sensor Monitor Sample", $"Getting Controller with FQID: {fqid.ObjectId}");
	Item item = Configuration.Instance.GetItemConfiguration(SensorMonitorDefinition.SensorMonitorPluginId, _kind, fqid.ObjectId);
	if (item == null)
			return null;
	return new ControllerItem(item);
What I noticed was that there are several calls being made to the Event Server when I have a Smart Client open.
The calls are basically the same, but keep repeating between Controller and Sensor items, over and over.
2024-07-01 11:35:49.739+01:00 [    60] INFO       - Sensor Monitor Sample  Getting Controller with FQID: 6ad0eb21-bf67-400b-b4b2-90764d0a92be
2024-07-01 11:35:49.739+01:00 [    60] INFO       - Sensor Monitor Sample  Getting Sensor with FQID: 2ad9ebac-00a2-4561-93d0-a44f124a7feb
2024-07-01 11:35:49.739+01:00 [    60] INFO       - Sensor Monitor Sample  Getting Controller with FQID: 61e43569-5ef7-461b-a9d5-b578d2fd3d92
2024-07-01 11:35:49.739+01:00 [    60] INFO       - Sensor Monitor Sample  Getting Sensor with FQID: 1b590499-12c5-4562-bf37-b461fcfca4a6
I’m just asking since I wonder if this amount of calls can have an impact on the AppDomain memory, if I have a large amount of items created (hundreds of sensors and controllers created).
Is this normal behaviour or is there a better to get items on the map?
I’m using a 2023 R3 Professional+ version to test this.
Thanks.
Hi Guillaume,
That is an intended behavior. The Map ( legacy Map, not Smart Map) uses a polling model to get data and updates for items and devices on the map. It does a few calls. It’s not great, but this is how it’s always been.
Hi Rie,
Thank you for the answer.
Indeed it is not optimal, but if it is limited to the legacy Map it is understandable.
I will check Smart Map behavior since I didn’t test on it.
