Which of the following SOAP endpoints are available in 2022 R3 and higher versions? I had thought that only one of the following was available based upon the XProtect release but I no longer believe that is the case. I am seeing that one or the other is working depending upon the instance of 2022 R3.
1. /ServerAPI/ServerCommandService.asmx
2. /ManagementServer/ServerCommandService.svc
Both are still supported on all versions, but as is also stated here the .asmx one should be considered deprecated and will eventually be removed on future versions:
https://doc.developer.milestonesys.com/html/index.html?base=gettingstarted/intro_soap_protocols.html&tree=tree_3.html
Thank you for the response. The linked document indicates that the /ServerAPI/ServerCommandService.asmx endpoint only supports Windows authentication and port 80. This is different from my experience in that I find that port 443 is supported. Can you confirm that TLS on port 443 is supported?
Also, we have many XProtect installations and the version differs across them. Can you provide what versions of XProtect support each endpoint? This information would help determine when /ServerAPI/ServerCommandService.asmx can be fully removed on our side.
Yes, I can confirm, it is supported in all supported versions. It has truly been marked deprecated for a long time but has neither been removed nor changed.
Could it be that the /ServerAPI/ServerCommandService.asmx endpoint has not been removed because it supports Windows authentication over TLS even though the documentation would disagree with this while /ManagementServer/ServerCommandService.svc does not? Thus leaving a gap.
I know that this is the one we should recommend.. /ManagementServer/ServerCommandServiceOAuth.svc
It was introduced in 2021R1, so this too will now support all supported versions.
Should /ManagementServer/ServerCommandServiceOAuth.svc support Windows authentication over TLS?
You should login on the IDP and use the token towards ServerCommandServiceOAuth. See the notes on OpenID Connect and OAuth2 here - https://doc.developer.milestonesys.com/html/index.html?base=gettingstarted/intro_soap_protocols.html&tree=tree_3.html
I asked an expert developer colleague, he said that my answer about using OAuth is the best possible answer. However he could explain the services and their differences like this:
ServerCommandService.svc har to end-points:
- a wsHttpBinding
- uses message based security
- can only e consumed by .net WCF clients
- only windows authenticcation
- a basicHttpBinding
- uses TLS
- can be consumed by non-wcf clients
- only basic authentication
- old soap service
- supports communication both with and without TLS
- uses Windows authentication (authenticated by IIS)
ServerCommandServiceOAuth (preferred)
- uses basicAuthentication
- supports TLS
- requires token from IDP
