Setup Mode: "View item is read-only..."
Hi everyone,
I am using XProtect Professional+ trial license.
I am using BoundingBox MetaProvider example. At smart client, i choose “setup” mode to verify viewing box option was disable or enable.
However, in “Properties” tab, it showed “view item is read-only…” like the attached file.
So could you point me where i need to change ?
Thanks,
It is a kind of mystery for us that your Views is 0 according to your image. Could you please describe how you created this situation?
Please create a view in your Smart Client and try to test it once more.
