Show a ToolbarPluginWpfUserControl as a modal
Dear,
I’ve implemented a UserControl based on ToolbarPluginWpfUserControl. When I click somewhere outside of the ToolbarPluginWpfUserControl the UserControl is dismissed.
Is it possible to keep the ToolbarPluginWpfUserControl on top and have it closed by a user similar to the “Add to incident project” button/window?
Thanks,
Bart
Solved with the following code:
   public override ToolbarPluginWpfUserControl GenerateWpfUserControl()
	   YourToolbarPluginWpfUserControl control = new YourToolbarPluginWpfUserControl(this);
	   _dlg = new Window
		   Content = control,
		   SizeToContent = SizeToContent.WidthAndHeight,
		   Owner = Application.Current.MainWindow,
		   ResizeMode = ResizeMode.NoResize,
		   WindowStyle = WindowStyle.ToolWindow,
	   _dlg.Closing += (s, e) =>
		   control.Visibility = Visibility.Collapsed;
		   control.Close();
	   _dlg.ShowDialog();
	   return control;
That is amazing good news. The expert I consulted did not return yet so I am very happy to hear you solved it. Thanks for sharing.
