Xprotect Corporate:
I have a problem connecting to the corporate server using smart client 2016 (on LAN) (using pc - win 7 ultimate, win8 works fine, using pc - win 7 professional sp1 not works - I do not know if the version of windows is of any importance). Smart Client instal on win7 professional generate the next error:
{2017-05-17 11:41:33.442+03:00 [ 1] INFO - Application started. (10.0a (64-bit) Build: 956)
2017-05-17 11:42:22.150+03:00 [ 7] DEBUG - Requesting for serviceregistration on http://10.0.4.51/ServerAPI/ServiceRegistrationService.asmx
2017-05-17 11:42:22.201+03:00 [ 7] DEBUG - Requesting for serviceregistration on https://10.0.4.51:443/ManagementServer/ServiceRegistrationService.svc
2017-05-17 11:43:39.082+03:00 [ 1] INFO - Application started. (10.0a (64-bit) Build: 956)
2017-05-17 11:44:30.972+03:00 [ 7] DEBUG - Requesting for serviceregistration on http://10.0.4.51/ServerAPI/ServiceRegistrationService.asmx
2017-05-17 11:44:31.024+03:00 [ 7] DEBUG - Requesting for serviceregistration on https://10.0.4.51:443/ManagementServer/ServiceRegistrationService.svc
2017-05-17 11:44:43.263+03:00 [ 7] DEBUG - The request for serviceregistration on https://10.0.4.51:443/ManagementServer/ServiceRegistrationService.svc succeeded
2017-05-17 11:44:43.297+03:00 [ 14] DEBUG - Opening connection on https://user-pc/ManagementServer/ServerCommandService.svc
2017-05-17 11:44:47.412+03:00 [ 14] DEBUG - Opening connection on https://user-pc/ManagementServer/ServerCommandService.svc failed with VideoOS.Common.CommandApi.CommandAPIInternalException->System.ServiceModel.EndpointNotFoundException}
Thank you in advance.
