Smart client keeps saying that the API key is invalid for Google Maps, has anyone set this up successfully? The Milestone support team is not helpful and referred me here.
You might find this useful - https://developer.milestonesys.com/s/article/Smart-Map-setup-guide
I am sorry if the Milestone Support Team referred you here because it is the wrong place. Setting up Smart Map is not development work using the MIP SDK.
This is a question better suited for the Milestone Support Community.
I have but the problem is the Free API key from google is very limited. i used up the free version in 2 hrs setting it up. It will cost a lot of money to use Google maps. I have contacted them and based on what we would use. The API from Google and Bing would cost our customer over $10,000 a month. We switched to static Google pictures of the areas. If you contact Google or Bing it takes both of them about 2 weeks to get back to you. Good Luck
How te API google key should would look like in Milestone config? I using key with HikCentral and it works perfect. In Milestone documantion there is no help to make this setup.
Let me repeat the previous answer, you might find this useful - https://developer.milestonesys.com/s/article/Smart-Map-setup-guide
