Dear all
My problem is to start smart client via the commandline with given cameras. Starting in live as in replay mode. Works fine with a single camera as shown below. But it seem that the command for multy cameras do not work correct.
Work fine
Do not work
The command do not work
SCS.Views.ShowCameras(“Camara1”, “Default group”, “Default view group”, “M4”);
The alternative variant to coose a given view and st a camera to a specific position also do not work.
SCS.Views.SetCameraViewItemCamera(“2”,”Camera1”)
In a script as well as in the given about:script sample.
Is there a running example about that stuff or do you are able to recommend easy to use alternatives.
Dierk
