smart map plugin icons
hi,
i have a problem in witch i add icons via the definitions class and i cannot see those items in the smart map item adding in setup tree. the problem is that on the regular map the items appear properly.
I am not sure what can be the problem here and is there any difference between adding smart map item and regular map item.
I have seen the SensorMonitor sdk and havent found any difference between the way that the icons appear there and in my plugin.
Thank you
Can you please verify that unmodified Sensor Monitor sample works for you?
Which product and version is the XProtect VMS used? Which version of the MIP SDK are you using?
