I’m writing a MIPS plugin in C#. It does several things, but one of my tasks is to get a live camera stream and stream it to our own application’s server. We need the stream in RTSP format. I need some advice as to how to tackle it.
I have looked at the Protocol sample TcpVideoViewer, and I see how it gets a stream. But it appears to me that you can only get MJPEG or the camera’s raw stream that way. (Could the raw stream be transcoded on the fly, before sending it on?)
I have looked at the component sample MediaLiveServiceJPEG_cpp. It too gets a live stream, and I see how the stream is configured with xml ( …). I can see that it’s encoded as jpeg, but I haven’t found any documentation for the config XML to see if it allows encoding as RTSP. (I don’t mind adding a C++ DLL to the mix.)
And just now, I noticed a post asking about getting RTSP streams using the ONVIF bridge, implying that it is possible there too.
So what’s the recommended way to attack this?
