Support- MIP SDK : Customer is requesting access to our API. They have developed a custom platform, hosted in Azure, and would like to integrate with XProtect to create bookmarks. Could we please assist by providing them guidance on the templates
I’m not sure I understand what you want to develop.
I would like to point to a sample that shows how you can create bookmarks via code, if this does not lead you to be able to develop your solution please elaborate on the question.
This sample shows you how you can create bookmarks. - https://doc.developer.milestonesys.com/html/index.html?base=samples/componentsamples/bookmarkcreator/readme.html&tree=tree_2.html
After the sample was made a new method has been introduced; there is now also methods in the REST API. There is no sample is showing the use but the documentation is found here.-
https://doc.developer.milestonesys.com/mipvmsapi/api/bookmarks-rest/v1/
Thank you — this is helpful. We’re currently working to gain a clear understanding of the client’s objectives
