I am using Milestone Server 2020R3, direct streaming is enabled on the Mobile server and the “VideoStream” sample code works fine.
The test code that I wrote does the following after the window load event:
1 - automatically connects to the server.
2 - once connected, automatically logs in.
3 - once logged in, goes through the views and creates a videos-stream node and adds it.
When doing it this way, I get a “Could not start direct streaming” message. I put in some extra addeventhandlers to capture events from the videos-stream to see what was happening. In there, it logged a lot of “beginVideoStuck” events, and eventually CloseStream was issued.
When I have it connect, login, display video through a button click, it works. The video creates a lot of “endVideoStuck” events though. in the “VideoStream” example code, it does not have any “beginVideoStuck” or “endVideoStuck” events.
Below is my single page test code.
<!DOCTYPE html>
<html>
<head>
<link rel="stylesheet" type="text/css" href="lib/css/sample.css">
<script type="module" src="lib/modules/VideoConnection/main.js"></script>
<script type="module" src="lib/modules/VideoStream/main.js"></script>
<script src="lib/js/polyfill-webcomponents-bundle.js"></script>
<script src="lib/js/XPMobileSDK.js"></script>
</head>
<body>
<section id="login-form-container">
<div>
<label>
<span class="label-text">Server</span>
<input type="text" class="server-name input" name="server" id="server" value="https://localhost:8082" />
</label>
<label>
<span class="label-text">Username</span>
<input type="text" class="username input" name="username" id="username" value="testacct" />
</label>
<label>
<span class="label-text">Password</span>
<input type="password" class="password input" name="password" id="password" value="password" />
</label>
<div>
<button type="button" class="login-button button" id='connect'>Connect</button>
</div>
</div>
</section>
</body>
<section id='streams-container'>
</section>
<script>
var observer;
var credentials;
document.querySelector('#connect').addEventListener('click', StartLive);
window.addEventListener('load', function()
StartLive();
function StartLive() {
var tserver = document.querySelector('#server').value;
var tusername = document.querySelector('#username').value;
var tpassword = document.querySelector('#password').value;
var creds = {
url: tserver,
username: tusername,
password: tpassword
initMilestone(creds);
function initMilestone(cred) {
credentials = cred;
if (observer) {
XPMobileSDK.removeObserver(observer);
observer = {
connectionDidConnect: connectedToServerHandler,
connectionDidLogIn: loggedInHandler,
connectionLostConnection: lostConnectionHandler
XPMobileSDKSettings.MobileServerURL = credentials.url;
XPMobileSDK.addObserver(observer);
XPMobileSDK.connect(credentials.url);
function connectedToServerHandler() {
XPMobileSDK.login(credentials.username, credentials.password, {
SupportsAudioIn: 'Yes',
SupportsAudioOut: 'Yes'
function loggedInHandler() {
LoadVideo();
function lostConnectionHandler() {
console.log("Connection to server lost");
function streamError(event) {
console.log("Stream Error: " + event.type);
function LoadVideo() {
if (!XPMobileSDK.library.Connection.directStreamingServer) {
alert('Your server does not support Live Direct Streaming!');
} else {
XPMobileSDK.getAllViews(function(items) {
for (var i = 0; i < items[0].Items[0].Items[0].Items.length; i++) {
let videoElement = document.createElement('videos-stream');
videoElement.cameraId = items[0].Items[0].Items[0].Items[i].Id;
videoElement.name = items[0].Items[0].Items[0].Items[i].Name;
document.body.appendChild(videoElement);
videoElement.dispatchEvent(new CustomEvent('start'));
videoElement.addEventListener('beginVideoStuck', streamError);
videoElement.addEventListener('endVideoStuck', streamError);
videoElement.addEventListener('restartStream', streamError);
videoElement.addEventListener('fallback', (event) => {
let player = event.target.shadow.lastElementChild.getElementsByClassName('player')[0];
let errorMsg = document.createElement('div');
errorMsg.innerHTML = "Could not start direct streaming.";
player && player.parentNode.appendChild(errorMsg);
player && player.parentNode.removeChild(player);
errorMsg = null;
player = null;
</script>
</html>
