(Not NuGet download), After install I don’t see a Bin for x86. With installed lib I can compile target x86, but runtime get error. Question: What version SDK I have to use to get redistributable x86 ?
Can you please get Redistributable Installer x86 and see if the issue happens again? Please make sure to refer x86 dlls in your project.
There are 2 options for downloading it.
Please go to Milestone web site ([https://www.milestonesys.com/](https://www.milestonesys.com/ "https://www.milestonesys.com/")). Login to MyMilestone. Click “Application Track” and you will see Application Track page. Please find “Get Started with the MIP SDK” in the page and expand it. You will find MIP SDK 2021 R1 – Redistributable Installer x86 there.
If you are not MyMilestone member then please download the installer here - [download.milestonesys.com\\MIPSDK\\MIPSDK\_Redist\_Installer\_x86\_2021R1.msi](https://download.milestonesys.com/MIPSDK/MIPSDK_Redist_Installer_x86_2021R1.msi "https://download.milestonesys.com/MIPSDK/MIPSDK_Redist_Installer_x86_2021R1.msi")
Install path will be something like this - (Drive name):\Program Files (x86)\Milestone\MIPSDK\Bin
