Toggle off: Toggle mode, Log out and Settings.
Im using XProtect Professional 2016 R3.
And i want to toggle off: Toggle mode, Log out and Settings.
Is this possible? Do i need to do this in the client or at the server?
Greetings,
Thom Stouten
I am assuming it is in the Smart Client you want to control so that the user cannot make his own choice between Simplified and Advanced mode, cannot logoff and cannot go into settings.
You cannot control this in the XProtect Professional version.
In the XProtect Corporate and XProtect Expert versions you have Smart Client profiles and can control this.
This question might not be a development question, but unfortunately the answer is the same if using MIP SDK development methods.
