Toolbar's botton does not work after swapping the item
After swapping the item, the toolbar’s botton does not work.
Do you have any solutions?
The sample of “Background color View Item” also does not work.
1. Create multi views (e.g 2 views).
2. Swapping the item.
3. Click the swapped item botton.
I was able to reproduce your observation. I will investigate deeper and involve Milestone Development.
Thank you for your prompt response.
Milestone Development was able to develop a fix. The fix is part of the Smart Client code. The fix will be in the Smart Client 2018R2 release with expected release date June 5.
Thank you! I will confirm next SC.
