Hi all,
I have a question about the transaction Session ID.
According documentation: "Defines a custom property of a transaction connector, which should be set when configuring a transaction source. "
and
Guid VideoOS.Platform.Transact.Services.DataContracts.StartLiveSessionParameters.SourceId
"The id of the transaction source, on which to start a live session. "
My understanding Item Transact key property “TransactConnectorId” is transaction source, which is used to get session id?
I tried to use StartLiveSessionParameters.SourceId =TransactConnectorId and then StartLiveSessionAsync, but I got unknown source, TransactConnectorId is not empty.
Where can I get transaction source from ? Why it is unknown?
Any help would be appreciated.
Thank you
The StartLiveSessionParameters.SourceId is the ID of the transaction source in question (which is part of the MIP configuration – represented with the TransactSourceItem class).
The TransactSourceItem.TransactConnectorId is the ID of the connector that this source uses. The TransactConnectorId is not used when starting a live session.
Given a TransactSourceItem source and an ITransactQueryClient client , the way to start a live session is:
var startLiveSessionParameters = new StartLiveSessionParameters()
SourceId = source.FQID.ObjectId,
PrecedingLineCount = …
var startLiveSessionResult = await client.StartLiveSessionAsync(startLiveSessionParameters);
var getLiveLinesParameters = new GetLiveLinesParameters()
SessionId = startLiveSessionResult.SessionId,
Timeout = …
var getLiveLinesResult = await client.GetLiveLinesAsync(getLiveLinesParameters);
Thank you a lot for your answer! I will try
