Trigger Analytics Event using the Rest API
Hi
I want to trigger an analytic event using the Rest API of Milestone. Does the Milestone system allow the trigger of analytic events with the Rest API?
If I try to get an alarms list the API response is as follows:
"error": {
    "httpCode": 404,
    "details": \[
            "errorText": "Unknown resource: alarms"
We are running on Milestone 2022 R1
The Alarms API is beta and was introduced in 2023R2.
ref. https://doc.developer.milestonesys.com/html/index.html?base=gettingstarted/mip2023r2_intro.html&tree=tree_home.html
https://doc.developer.milestonesys.com/mipvmsapi/api/alarms-rest/v1/#section/Quickstart/Requirements
It will unfortunately not work in systems older than 2023R2..
