Unable to register plugin on solution partner portal
I want to use Milestone Licensing Framework in order to protect our plugin as is described on Milestone Solution Partner Licensing Framework. I am not able to follow procedure, because in our portal there is not the “MIP Plug-in management” button. My question is: “MIP Plug-in management” button and Licensing Framework usage require any further registration step or entitlement?
I also experience the button missing. I will raise it with the Milestone web development team. Thank you for reporting this. I will update here when I learn more..
The missing button links to - https://www.milestonesys.com/my-milestone/msp/mip-plugin-management/
Hopefully you can use the link and get going. Let me know if you do not get through.
Our web developers will enable the button, but for fastest resolution please use the link..
