Use API to add configured events to camera
In the management client there is an “Events” tab for a camera that allows me to tell Milestone that the camera supports a specific event - for example, Motion Started (HW).
I’d like to automate this configuration, so that the user doesn’t have to manually apply this to each of their (dozens of) ONVIF cameras.
However, I can’t even find the values in the camera configuration via the API.
The client API example doesn’t have this tab either.
Is this supported via the API ?
Unfortunately it is not supported in the Configuration API.
It is the future plans to implement this for the Configuration API, but it has currently not been prioritized..
See also - https://developer.milestonesys.com/s/question/0D50O00004fA29oSAC/
Thanks.
That’s unfortunate. Without an (/any) event registered against the camera, Milestone does not appear to initiate a (ONVIF) PullPointSubscription of its own accord.
We’ll add a note to our documentation.
Thanks for the link. My searching powers obviously failed me that day :slight_smile:
