I tried looking at documentation, that didnt help much. Hoping devs here can please point out to some hope for me. Thanks
I know that there are message for changing views, maybe there is something useful for you.
Please try to use the Message Test sample and see on the message tracer if a message happens that you can use for this.
You can always see if the window is there by use of the configuration, if there is a message but it is not conclusive you can check the configuration. Please explore the Configuration Dump plugin sample.
