Hey
I create a plugin base on the SDK Plugin example 'Smart Client View and Window Tool’ - ‘Playback Control’
In the while loop on file BackgroundPlugin.cs I add the a function that send the playback control massage -
_EnvironmentManager.Instance.SendMessage(_
_new VideoOS.Platform.Messaging.Message(_
_MessageId.SmartClient.PlaybackCommand,_
_new PlaybackCommandData()_
_{_
_Command = command,_
_DateTime = dateTime,_
_Speed = speed_
_}));_
I succeed to change from PlayForward to PlayReverse and etc.
But when I try to change the speed (for example from PlayForward x2 to PlayForward x5) I got exception
Way it’s happened ?
Thank you
This is the exception info:
************** Inner Exception **************
Exception type:System.InvalidOperationException
Exception message:The calling thread cannot access this object because a different thread owns it.
Exception source:WindowsBase
Exception Target Site: VerifyAccess
at System.Windows.Threading.Dispatcher.VerifyAccess()
at System.Windows.DependencyObject.GetValue(DependencyProperty dp)
at System.Windows.Controls.Primitives.ToggleButton.get_IsChecked()
at VideoOS.UI.Common.WPF.Timeline.Control.ControlsArea.Controls.PlaybackSpeedControl.set_PlaybackSpeed(PlaybackSpeed value)
at VideoOS.UI.Common.WPF.Timeline.Control.ControlsArea.ControlsArea.ApplyAppearanceAndBehaviourControllerProperty(String propertyName)
at System.ComponentModel.PropertyChangedEventHandler.Invoke(Object sender, PropertyChangedEventArgs e)
at VideoOS.UI.Common.WPF.Timeline.Control.Controllers.AppearanceAndBehaviourController.OnPropertyChanged(Enum fieldName)
at VideoOS.UI.Common.WPF.Timeline.Control.Controllers.AppearanceAndBehaviourController.set_PlaybackSpeed(PlaybackSpeed value)
at VideoOS.UI.Common.WPF.Timeline.Control.TimelineControl.set_PlaybackSpeed(Double value)
at VideoOS.RemoteClient.Application.UI.Timeline.SmartClientTimelineHelper.BrowseController_PlaybackSpeedChangedEvent(Object sender, PlaybackSpeedEventArgs e)
at System.EventHandler`1.Invoke(Object sender, TEventArgs e)
at VideoOS.RemoteClient.Application.Controllers.BrowseController.FirePlaybackSpeedChangedEvent(PlaybackSpeedEventArgs e)
at VideoOS.RemoteClient.Application.Controllers.BrowseController.SetPlaybackSpeed(Double playbackSpeed, Boolean isFromLocalSource)
Exception type:System.Reflection.TargetInvocationException
Exception message:Exception has been thrown by the target of an invocation.
Exception source:mscorlib
Exception Target Site: InvokeMethod
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at VideoOS.RemoteClient.Application.Actions.ActionBase.InvokeAction(Object[] parameters)
at VideoOS.RemoteClient.Application.MIP.Manager.MessageManager.ClientPlaybackCommandHandler(Message message, FQID dest, FQID source)
at VideoOS.RemoteClient.Application.MIP.Manager.SCEnvironmentManager.ExecuteMessage(Message message, FQID destination, FQID sender, String logMessage)
