Video Push Driver with PTZ functionality ? (Mobile Server)
Dear developers,
We are creating a App with Video Push Driver. The App is sending frames to server but we want integrate with PTZ functionality and communicate to the App (iOS or Android). Is there a example or a way to get PTZ informations with Video Push Driver and App ?
Thanks.
Hi Guilherme,
If I understand you correctly you need to receive PTZ commands fired from the Smart Client (for example) in your custom Android/iOS application based on the MIP SDK Mobile, that is performing video push.
If that is the case it is not possible.
Unfortunately Mobile server doesn’t process video push PTZ commands and doesn’t provide them to the clients.
If you want to use Milestone Mobile applications and communicate directly with them, I don’t think this is possible either.
I’ll ask around however for the last one, as I’m not hundred percent sure.
