I wanted to send command to configure a Smart Wall Monitor using the VideoWallApplyXmlCommand as shown in the MIPSDK VideoWallController sample.
Let’s say the scenario is I have the GUIDs of four cameras I wanted to send to Smart Wall Monitor 1, how can I generate the required XML?
The following xml is the sample I get from the mentioned MIPSDK sample, I realized that for one ViewItem, most of the xml attributes are just like default value so I only need to update two of the following attributes in ItemInfo:
lastknowncameradisplayname
cameraid
Except for the id attribute of the viewitem.
May I know how can I get and set it?
<viewitems>
<viewitem
id="db312f3a-cc99-4104-8ee4-e79e3d63588a"
displayname="Camera ViewItem"
shortcut=""
type="VideoOS.RemoteClient.Application.Data.ContentTypes.CameraContentType.CameraViewItem, VideoOS.RemoteClient.Application"
<iteminfo
cameraid="0c5360d7-82b9-423a-8522-325da2cb1ed6"
lastknowncameradisplayname="FLEXIDOME IP starlight 6000 VR (128.133.229.72) - Camera 1"
imagequality="100"
framerate="0"
ipixsplitmode="0"
maintainimageaspectratio="True"
keepimagequalitywhenmaximized="False"
updateonmotiononly="False"
soundonmotion="0"
soundonevent="0"
smartsearchgridwidth="0"
smartsearchgridheight="0"
smartsearchgridmask=""
<properties />
</viewitem>
Thanks.
